跳转到主内容
Garmin Dezl 760LMT Motherboard Replacement
你所需要的
  1. Garmin Dezl 760LMT Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Garmin Dezl 760LMT Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Motherboard Replacement: 步骤 2 中的图像 1,3 Garmin Dezl 760LMT Motherboard Replacement: 步骤 2 中的图像 2,3 Garmin Dezl 760LMT Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Motherboard Replacement: 步骤 3 中的图像 1,1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: 步骤 4 中的图像 1,2 Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: 步骤 4 中的图像 2,2
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Motherboard Replacement: 步骤 5 中的图像 1,2 Garmin Dezl 760LMT Motherboard Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Garmin Dezl 760LMT Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Using a Torx T5 screwdriver, unscrew the six 5mm screws on the motherboard.
  7. Garmin Dezl 760LMT Motherboard Replacement: 步骤 7 中的图像 1,3 Garmin Dezl 760LMT Motherboard Replacement: 步骤 7 中的图像 2,3 Garmin Dezl 760LMT Motherboard Replacement: 步骤 7 中的图像 3,3
    • Grasp each of the three wires near where it is attached to the motherboard. Lift them upward to detach them.
    • Lift the motherboard from the device.
结论
Ryan Williams
于09/28/16注册
763 声望
创作了6篇指南
团队
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G2
4 名成员
创作了6篇指南
2条评论
i realy appreciate the video but please tell me where can i find buy the motherboard or others parts for my gps rv-760
Thank you
Pierre Delisle
Québec
Canada
Pierre Delisle - 回复
Is it possible to buy the ribbon cable from the screen to the mother board, and what’s the procedure to replace it on the display ? Thanks
Kiki B - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,834
