跳转到主内容
Garmin Dezl 760LMT Battery Replacement
你所需要的
  1. Garmin Dezl 760LMT Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Garmin Dezl 760LMT Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Battery Replacement: 步骤 2 中的图像 1,3 Garmin Dezl 760LMT Battery Replacement: 步骤 2 中的图像 2,3 Garmin Dezl 760LMT Battery Replacement: 步骤 2 中的图像 3,3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Battery Replacement: 步骤 3 中的图像 1,1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Battery Replacement, Battery: 步骤 4 中的图像 1,2 Garmin Dezl 760LMT Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • This photo shows the use of a tool that is not ESD safe. Use a nylon spudger to complete this step.
    • Use a nylon spudger to pry the battery from the device.
    • During reassembly, place double-sided electrical tape under the battery before pressing it into its slot.
  5. Garmin Dezl 760LMT Battery Replacement: 步骤 5 中的图像 1,2 Garmin Dezl 760LMT Battery Replacement: 步骤 5 中的图像 2,2
    • Grasp the battery wire near the motherboard and lift upward to detach the connector.
结论
6等其他人完成本指南。
Ryan Williams
于09/28/16注册
763 声望
创作了6篇指南
团队
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G2
4 名成员
创作了6篇指南
2条评论
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
Pissedoff - 回复
you have to be more careful with your stuff dude..
Bealphares Voluptarius -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 5,897
