跳转到主内容
Garmin Dash Cam 20 Screen Replacement
你所需要的
  1. Garmin Dash Cam 20 Screen Replacement, Internal Assembly: 步骤 1 中的图像 1,2 Garmin Dash Cam 20 Screen Replacement, Internal Assembly: 步骤 1 中的图像 2,2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Screen Replacement: 步骤 2 中的图像 1,2 Garmin Dash Cam 20 Screen Replacement: 步骤 2 中的图像 2,2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Screen Replacement: 步骤 3 中的图像 1,2 Garmin Dash Cam 20 Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Screen Replacement: 步骤 4 中的图像 1,2 Garmin Dash Cam 20 Screen Replacement: 步骤 4 中的图像 2,2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Screen Replacement: 步骤 5 中的图像 1,3 Garmin Dash Cam 20 Screen Replacement: 步骤 5 中的图像 2,3 Garmin Dash Cam 20 Screen Replacement: 步骤 5 中的图像 3,3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Screen Replacement: 步骤 6 中的图像 1,3 Garmin Dash Cam 20 Screen Replacement: 步骤 6 中的图像 2,3 Garmin Dash Cam 20 Screen Replacement: 步骤 6 中的图像 3,3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Screen Replacement, Screen: 步骤 7 中的图像 1,3 Garmin Dash Cam 20 Screen Replacement, Screen: 步骤 7 中的图像 2,3 Garmin Dash Cam 20 Screen Replacement, Screen: 步骤 7 中的图像 3,3
    • Use the Phillips screwdriver to remove the four 5mm screws.
  8. Garmin Dash Cam 20 Screen Replacement: 步骤 8 中的图像 1,2 Garmin Dash Cam 20 Screen Replacement: 步骤 8 中的图像 2,2
    • Use the metal spudger to remove metal plate from device. This will reveal the screen.
  9. Garmin Dash Cam 20 Screen Replacement: 步骤 9 中的图像 1,3 Garmin Dash Cam 20 Screen Replacement: 步骤 9 中的图像 2,3 Garmin Dash Cam 20 Screen Replacement: 步骤 9 中的图像 3,3
    • Use the metal spudger to remove screen from device.
  10. Garmin Dash Cam 20 Screen Replacement: 步骤 10 中的图像 1,1
    • The screen is now detached.
结论
另外一个人完成了本指南。
Jesse Hillman
于10/04/16注册
757 声望
创作了5篇指南
团队
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 493
