跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will walk users through removing the top cover of the Garmin Dash Cam as well as the metal battery frame. Due to the compact nature of this device, this guide is a prerequisite to other guides that require access to the internal components of the device.
  1. Be sure to turn off the Dash Cam by pressing the power button. Be sure to turn off the Dash Cam by pressing the power button.
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Rotate the Dash Cam to where the socket faces you. Remove the 9 mm screw using the Torx T6 screwdriver.
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Remove the Dash Cam socket piece. Remove the Dash Cam socket piece.
    • Remove the Dash Cam socket piece.
  4. Rotate the Dash Cam to where the product information faces you. Remove the two 5 mm screws using the Torx T5 screwdriver.
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Remove top case from the bottom case. The compact nature of the casing requires use of the metal spudger for needed leverage. The compact nature of the casing requires use of the metal spudger for needed leverage.
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Remove the two 5mm screws using the Torx T5 screwdriver By removing the screws, the metal battery frame will now become free from the rest of the device. By removing the screws, the metal battery frame will now become free from the rest of the device.
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
结论
另外一个人完成了本指南。
Jesse Hillman
于2016年10月04日注册
736 信誉积分
创作了5篇指南
团队
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G1
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 47
