跳转到主内容
Garmin Dash Cam 20 Camera Lens Replacement
你所需要的
  1. Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: 步骤 1 中的图像 1,2 Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: 步骤 1 中的图像 2,2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 2 中的图像 1,2 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 2 中的图像 2,2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 3 中的图像 1,2 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 3 中的图像 2,2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 4 中的图像 1,2 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 4 中的图像 2,2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 5 中的图像 1,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 5 中的图像 2,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 5 中的图像 3,3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 6 中的图像 1,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 6 中的图像 2,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 6 中的图像 3,3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: 步骤 7 中的图像 1,2 Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: 步骤 7 中的图像 2,2
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
  8. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 8 中的图像 1,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 8 中的图像 2,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 8 中的图像 3,3
    • Remove the metal case off of the motherboard.
  9. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 9 中的图像 1,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 9 中的图像 2,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 9 中的图像 3,3
    • Remove the battery connection.
  10. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 10 中的图像 1,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 10 中的图像 2,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 10 中的图像 3,3
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
  11. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 11 中的图像 1,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 11 中的图像 2,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the connector on the top right of the motherboard.
  12. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 12 中的图像 1,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 12 中的图像 2,3 Garmin Dash Cam 20 Camera Lens Replacement: 步骤 12 中的图像 3,3
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
  13. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 13 中的图像 1,1
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
  14. Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: 步骤 14 中的图像 1,2 Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: 步骤 14 中的图像 2,2
    • Use the Torx T5 screwdriver to remove the two 5mm screws.
    • These screws hold the camera in place. Therefore, the lens will fall into the bottom case.
  15. Garmin Dash Cam 20 Camera Lens Replacement: 步骤 15 中的图像 1,1
    • The camera lens is now detached.
结论
Jesse Hillman
于10/04/16注册
757 声望
创作了5篇指南
团队
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 992
