跳转到主内容
Garmin Dash Cam 20 Battery Replacement
你所需要的
  1. Garmin Dash Cam 20 Battery Replacement, Internal Assembly: 步骤 1 中的图像 1,2 Garmin Dash Cam 20 Battery Replacement, Internal Assembly: 步骤 1 中的图像 2,2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Battery Replacement: 步骤 2 中的图像 1,2 Garmin Dash Cam 20 Battery Replacement: 步骤 2 中的图像 2,2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Battery Replacement: 步骤 3 中的图像 1,2 Garmin Dash Cam 20 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Battery Replacement: 步骤 4 中的图像 1,2 Garmin Dash Cam 20 Battery Replacement: 步骤 4 中的图像 2,2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Battery Replacement: 步骤 5 中的图像 1,3 Garmin Dash Cam 20 Battery Replacement: 步骤 5 中的图像 2,3 Garmin Dash Cam 20 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Battery Replacement: 步骤 6 中的图像 1,3 Garmin Dash Cam 20 Battery Replacement: 步骤 6 中的图像 2,3 Garmin Dash Cam 20 Battery Replacement: 步骤 6 中的图像 3,3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Battery Replacement, Battery: 步骤 7 中的图像 1,3 Garmin Dash Cam 20 Battery Replacement, Battery: 步骤 7 中的图像 2,3 Garmin Dash Cam 20 Battery Replacement, Battery: 步骤 7 中的图像 3,3
    • Remove the green tape overlying the pin connector with tweezers.
    • Remove the pin connector using tweezers.
    • Do not break black cord connection between motherboard and metal mount (orange circle).
  8. Garmin Dash Cam 20 Battery Replacement: 步骤 8 中的图像 1,3 Garmin Dash Cam 20 Battery Replacement: 步骤 8 中的图像 2,3 Garmin Dash Cam 20 Battery Replacement: 步骤 8 中的图像 3,3
    • This step shows the use of an incorrect tool. Only use ESD safe tools when handling the battery.
    • With the the nylon spudger, lift the battery to expose and stretch the glue. Cut the glue residue by gliding the tool from left to right.
结论
3等其他人完成本指南。
Jesse Hillman
于10/04/16注册
757 声望
创作了5篇指南
团队
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G1
4 名成员
创作了5篇指南
3条评论
An excellent article except for one major problem but, why does iFixIt not sell theses batteries or direct you on where a person could actually buy one? This knowledge is pretty much useless with out a replacement battery to actually use.
Bradley Hyman - 回复
Thanks for this guide. This gave my Garmin 20 another couple of years! :)
BTW, I was able to buy the battery replacement from Amazon: https://www.amazon.com/gp/product/B07KSR...
pro cabales - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 44
总计 3,835
