跳转到主内容
Garmin Approach S2 Motherboard Replacement
你所需要的
  1. Garmin Approach S2 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Garmin Approach S2 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
  2. Garmin Approach S2 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover carefully.
    • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
  3. 注意:步骤 3 源自标记为进行中的 指南
    Garmin Approach S2 Motherboard Replacement, Water Proof Gasket: 步骤 3 中的图像 1,1
    • Remove the orange gasket.
  4. Garmin Approach S2 Motherboard Replacement, Screen: 步骤 4 中的图像 1,1
    • Remove the screen and motherboard assembly from the case.
  5. Garmin Approach S2 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
  6. Garmin Approach S2 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the screen from the golden metal clip.
  7. Garmin Approach S2 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
  8. Garmin Approach S2 Motherboard Replacement: 步骤 8 中的图像 1,2 Garmin Approach S2 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the connector from the motherboard by pulling it free at the base.
    • Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
  9. Garmin Approach S2 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the screen from the motherboard.
    • Notice our tape retaining the connector to the screen. This is so easy to rip!
  10. Garmin Approach S2 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Remove the motherboard from the screen.
结论
Evan Miller
于03/21/18注册
250 声望
创作了2篇指南
团队
IUPUI, Team S4-G1, Baechle Spring 2018 IUPUI, Team S4-G1, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S4G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 687
