跳转到主内容
Garmin Approach S2 Battery Replacement
你所需要的
  1. Garmin Approach S2 Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Garmin Approach S2 Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
  2. Garmin Approach S2 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover carefully.
    • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
  3. Garmin Approach S2 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • On the back cover use a plastic opening tool to remove the green tape retaining the battery.
  4. Garmin Approach S2 Battery Replacement: 步骤 4 中的图像 1,2 Garmin Approach S2 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the green tape shrouding the battery connector.
  5. Garmin Approach S2 Battery Replacement: 步骤 5 中的图像 1,2 Garmin Approach S2 Battery Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the ESD safe tweezers to push the connector and metal shroud out from the back of the connector.
    • Remove the third and fourth wires from the right of the connector (as seen when looking from the angle in the photo). They should be red and black respectively.
    • DO NOT attempt to pull the wire from the connector, it will pull the wire from the metal shroud shown in the red box, which needs to be preserved for the connection to be successful.
  6. Garmin Approach S2 Battery Replacement: 步骤 6 中的图像 1,1
    • Use the ESD safe tweezers to break the adhesive between the back cover and the battery.
    • Remove the battery.
  7. Garmin Approach S2 Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the green tape on the back of the battery, it can be reused later.
结论
6等其他人完成本指南。
Emily Kovacs
于03/21/18注册
259 声望
撰写一个指南
团队
IUPUI, Team S4-G1, Baechle Spring 2018 IUPUI, Team S4-G1, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S4G1
3 名成员
创作了5篇指南
8指南评论
If anyone is looking for the replacement battery for the Approach S2 it can be found here:
Replacement Battery for Garmin Approach S2
It also included the T5 Torx and Opening Tools that are needed.
michaelf33707 - 回复
Step 6 shows 2 red wires each with a free end. One of these red wires has the non free end connected to the charging circuit terminal but there is no mention in Step 6 of disconnecting this wire or where the free end is connected to.
Paul Stevenson - 回复
This is a great tutorial for the S2. In my case I accidentally dropped one metal shroud (referred to in Step 5). I scoured the area on my hands and knees to no avail. Can you direct me to where I might obtain this part?or perhaps the entire connector? Thank you….
Brian Mahoney - 回复
Hi, Where the !&&* Can I buy a Replacement Battery for The Garmin S2 Golf watch.????.
Gregory John Wickenden - 回复
Gregory, I got my replacement via Amazon (UK). Battery came from Germany in about 1 week. Not cheap, but a lot cheaper than a new watch.
john.joice - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 56
过去 30 天: 262
总计 44,519
