跳转到主内容
加入维修社区 - 创建账户
Gardena BS-XL Spring Replacement
你所需要的
  1. Gardena BS-XL Spring Replacement, disconnect the blades: 步骤 1 中的图像 1,1
    • The bolt holding the 2 blades together is typically fastened with threadlocker from the factory to prevent the bolt from undoing itself when in use.
    • While holding the shears in a vise, undo the T30 bolt holding the 2 blades together.
  2. Gardena BS-XL Spring Replacement, remove the broken spring: 步骤 2 中的图像 1,3 Gardena BS-XL Spring Replacement, remove the broken spring: 步骤 2 中的图像 2,3 Gardena BS-XL Spring Replacement, remove the broken spring: 步骤 2 中的图像 3,3
    • This step assumes the spring is broken in the middle.
    • Remove the first part of the broken spring from the handle.
    • Pull the blade from the handle.
    • Remove the second part of the broken spring from the handle. If it is stuck, you can use a flathead screwdriver to wriggle it loose.
  3. Gardena BS-XL Spring Replacement, insert the new spring: 步骤 3 中的图像 1,3 Gardena BS-XL Spring Replacement, insert the new spring: 步骤 3 中的图像 2,3 Gardena BS-XL Spring Replacement, insert the new spring: 步骤 3 中的图像 3,3
    • Slide the new spring into the handle, and make sure there is room for the blade behind it.
    • Slide it in as far as it will go.
    • Push the blade back in until the handle hole aligns with the blade hole. This will put tension on the spring.
  4. Gardena BS-XL Spring Replacement, connect blades: 步骤 4 中的图像 1,3 Gardena BS-XL Spring Replacement, connect blades: 步骤 4 中的图像 2,3 Gardena BS-XL Spring Replacement, connect blades: 步骤 4 中的图像 3,3
    • Apply some threadlock on the bolt.
    • Align both blades and insert the nut. Screw in the bolt partially.
    • Ensure the spring is level and pushing against the other blade.
    • Fasten the bolt while opening and closing the shears to make sure it is neither to loose or too tight, and also to verify the spring is working correctly.
终点
另外一个人完成了本指南。
knipwim
于09/01/18注册
14,906 声望
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 72
总计 1,427
