跳转到主内容
Garbage Disposal Replacement
  1. Garbage Disposal Replacement, Garbage Disposal: 步骤 1 中的图像 1,1
    • Before installing your garbage disposal, make sure both your pipes and garbage disposal mount (pictured at the top) are aligned correctly to support your model.
  2. Garbage Disposal Replacement: 步骤 2 中的图像 1,1
    • Attach your garbage disposal to the mount (circled) that is attached to the sink hole.
  3. Garbage Disposal Replacement: 步骤 3 中的图像 1,1
    • Connect the silver mounting hardware attached to the top of the garbage disposal by turning it clockwise.
    • Mount disposal to the sink using one hand to lift it and the other to attach to the silver mounting hardware while making sure to match the grooves of your disposal into the mount. The disposal should now be all in one piece.
  4. Garbage Disposal Replacement: 步骤 4 中的图像 1,3 Garbage Disposal Replacement: 步骤 4 中的图像 2,3 Garbage Disposal Replacement: 步骤 4 中的图像 3,3
    • After mounting the disposal in place, align the black disposal pipe with the white PVC pipe connected to the sink.
  5. Garbage Disposal Replacement: 步骤 5 中的图像 1,1
    • Connect the dishwasher drain tube to the garbage disposable.
  6. Garbage Disposal Replacement: 步骤 6 中的图像 1,1
    • Once everything is in place, tighten all of your tube rings to ensure no leakage occurs.
  7. Garbage Disposal Replacement: 步骤 7 中的图像 1,1
    • Install and plug electrical wire into the correct power source. Test your disposal switch and check for any signs of leakage.
结论
Be sure to test your garbage disposal before sending any waste down the drain. Happy disposing!
5等其他人完成本指南。
1指南评论
There is a tiny hose that attaches to an air compressor. It keeps falling off.
Nancy Raza - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 48
过去 30 天: 238
总计 5,361
