简介
This guide will walk you through replacing the motor unit for a garage door opener. This includes taking the opener unit off the mounting rack and the chain rail. This guide will also cover the replacement of the safety laser sensors. This repair might be needed in the event of a failed opener system.
It is important to use caution because your opener unit is a heavy piece of equipment and could be dangerous if mishandled. To avoid any possible issues, it is wise to use a sturdy ladder underneath the unit to support the system throughout the following steps in the procedure. Be sure to unplug the unit before beginning this guide. Make sure you have all of the necessary tools and a few spare hours to get this done (if you haven't done this before). Strap in!
你所需要的
To reassemble your device, follow these instructions in reverse order. Make sure to bolt the rail back to the new unit, reattach the chain to the rail and unit, properly bolt the unit back to the rail, and rewire your new (or old) sensors to the unit.
After that, enjoy your new unit! A good motor unit should last you for at least a decade, and the units that can be bought now have plenty of features to keep you as excited as any garage door opener can excite you. At this point, you have likely saved a few hundred dollars on a service that anyone can do on their own with a bit of instruction.
Thank you for reading the guide, and we hope that it's helped you understand your garage more personally.
另外一个人完成了本指南。
