跳转到主内容
Gamestop G3 Gamecube Left and Right Trigger Replacement
你所需要的
  1. Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: 步骤 1 中的图像 1,3 Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: 步骤 1 中的图像 2,3 Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: 步骤 1 中的图像 3,3
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
  2. Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 2 中的图像 1,3 Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 2 中的图像 2,3 Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 2 中的图像 3,3
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
  3. Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 3 中的图像 1,3 Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 3 中的图像 2,3 Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 3 中的图像 3,3
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
  4. Gamestop G3 Gamecube Left and Right Trigger Replacement, Left and Right Trigger: 步骤 4 中的图像 1,2 Gamestop G3 Gamecube Left and Right Trigger Replacement, Left and Right Trigger: 步骤 4 中的图像 2,2
    • Remove the screws holding the plastic bumper cover in place and remove it.
  5. Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 5 中的图像 1,3 Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 5 中的图像 2,3 Gamestop G3 Gamecube Left and Right Trigger Replacement: 步骤 5 中的图像 3,3
    • At this point you should be able to remove the bumper along with its spring from the controller.
    • Clean thoroughly underneath the bumper and remove any dirt or debris before reattaching.
    • To reassemble the device, follow these steps in reverse order.
结论
John Harrison
于10/28/16注册
213 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 317
