跳转到主内容
GameStop Universal System Selector Button Replacement
你所需要的
  1. GameStop Universal System Selector Button Replacement, Button: 步骤 1 中的图像 1,1
    • Disconnect the DC 6V IN power cable from the device.
    • Remove the three front panel screws on the bottom of the device using the Phillips #00 Screwdriver.
  2. GameStop Universal System Selector Button Replacement: 步骤 2 中的图像 1,1
    • Carefully pry off the front panel of the device to reveal the button in need of replacement.
    • The outer piece of the device is plastic and may break it not carefully handled.
  3. GameStop Universal System Selector Button Replacement: 步骤 3 中的图像 1,2 GameStop Universal System Selector Button Replacement: 步骤 3 中的图像 2,2
    • Pull firmly on the button in need of replacement to free it from its housing.
  4. GameStop Universal System Selector Button Replacement: 步骤 4 中的图像 1,1
    • Gently push the replacement button into the housing.
  5. GameStop Universal System Selector Button Replacement: 步骤 5 中的图像 1,1
    • Snap the front panel back into place.
    • Replace the 3 front panel screws.
结论
The system selector button should now be working properly. Take your e-waste to an R2 or e-Stewards certified recycler.
另外一个人完成了本指南。
Jared
于10/28/13注册
201 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-6, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-6, Vijaybhaskar Fall 2013 的会员
UMASSD-VIJAYBHASKAR-F13S4G6
4 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 565
