跳转到主内容
GameStop GS3 GameCube Controller joysticks replacement
你所需要的
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: 步骤 1 中的图像 1,2 GameStop GS3 GameCube Controller joysticks replacement, Joysticks: 步骤 1 中的图像 2,2
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: 步骤 2 中的图像 1,1
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: 步骤 3 中的图像 1,3 GameStop GS3 GameCube Controller joysticks replacement: 步骤 3 中的图像 2,3 GameStop GS3 GameCube Controller joysticks replacement: 步骤 3 中的图像 3,3
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: 步骤 4 中的图像 1,3 GameStop GS3 GameCube Controller joysticks replacement: 步骤 4 中的图像 2,3 GameStop GS3 GameCube Controller joysticks replacement: 步骤 4 中的图像 3,3
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: 步骤 5 中的图像 1,3 GameStop GS3 GameCube Controller joysticks replacement: 步骤 5 中的图像 2,3 GameStop GS3 GameCube Controller joysticks replacement: 步骤 5 中的图像 3,3
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
结论
Andrew Gonsalves
于10/20/16注册
226 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 31
总计 1,386
