跳转到主内容
GameStop GS3 GameCube Controller Motherboard Replacement
你所需要的
  1. GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Open the controller by unscrewing the screws located on the back panel
    • Separate the two halves of the controller.
  2. GameStop GS3 GameCube Controller Motherboard Replacement: 步骤 2 中的图像 1,3 GameStop GS3 GameCube Controller Motherboard Replacement: 步骤 2 中的图像 2,3 GameStop GS3 GameCube Controller Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the rumble-pack by unscrewing the screws located on on either side.
    • Remove the rumble pack to fully separate the two halves of the controller
  3. GameStop GS3 GameCube Controller Motherboard Replacement: 步骤 3 中的图像 1,3 GameStop GS3 GameCube Controller Motherboard Replacement: 步骤 3 中的图像 2,3 GameStop GS3 GameCube Controller Motherboard Replacement: 步骤 3 中的图像 3,3
    • Disconnect the motherboard from the front half of the controller by unscrewing the small screws around its perimeter.
    • The motherboard should separate and lift right out from the front half.
结论
John Harrison
于10/28/16注册
213 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 881
