跳转到主内容
加入维修社区 - 创建账户
GameStop GS3 GameCube Controller Buttons Replacement
你所需要的
  1. GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: 步骤 1 中的图像 1,3 GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: 步骤 1 中的图像 2,3 GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: 步骤 1 中的图像 3,3
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
  2. GameStop GS3 GameCube Controller Buttons Replacement: 步骤 2 中的图像 1,3 GameStop GS3 GameCube Controller Buttons Replacement: 步骤 2 中的图像 2,3 GameStop GS3 GameCube Controller Buttons Replacement: 步骤 2 中的图像 3,3
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
  3. GameStop GS3 GameCube Controller Buttons Replacement: 步骤 3 中的图像 1,3 GameStop GS3 GameCube Controller Buttons Replacement: 步骤 3 中的图像 2,3 GameStop GS3 GameCube Controller Buttons Replacement: 步骤 3 中的图像 3,3
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
  4. GameStop GS3 GameCube Controller Buttons Replacement, Buttons: 步骤 4 中的图像 1,1
    • Hold the controller as shown in the picture so that you can remove the circuit board.
    • The locations of screws to be removed in future steps are shown in red.
  5. GameStop GS3 GameCube Controller Buttons Replacement: 步骤 5 中的图像 1,2 GameStop GS3 GameCube Controller Buttons Replacement: 步骤 5 中的图像 2,2
    • Now that the back panel has been removed it should be easy to snap off the "Z" and "TURBO" buttons as shown in the images.
  6. GameStop GS3 GameCube Controller Buttons Replacement: 步骤 6 中的图像 1,1
    • Remove the two screws on the motherboard so that you can remove the motherboard from the front cover.
  7. GameStop GS3 GameCube Controller Buttons Replacement: 步骤 7 中的图像 1,1
    • Now your controller front panel should look similar to this.
    • Remove the rubber backings on the buttons shown in red.
    • Snap them back in when you go to put the controller back together.
  8. GameStop GS3 GameCube Controller Buttons Replacement: 步骤 8 中的图像 1,1
    • Remove the buttons and you should have what you see here.
结论
团队
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,192
