跳转到主内容
加入维修社区 - 创建账户
GameSir Tarantula Pro Joystick Replacement
你所需要的
  1. GameSir Tarantula Pro Joystick Replacement, Joystick Covers: 步骤 1 中的图像 1,3 GameSir Tarantula Pro Joystick Replacement, Joystick Covers: 步骤 1 中的图像 2,3 GameSir Tarantula Pro Joystick Replacement, Joystick Covers: 步骤 1 中的图像 3,3
    • Use the tip of a spudger to remove the rubber screw covers from the backs of the handles and the top edge of the back case.
    • Gently pry up each screw cover and lift it out.
    询问修复机器人
  2. GameSir Tarantula Pro Joystick Replacement: 步骤 2 中的图像 1,2 GameSir Tarantula Pro Joystick Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the 4.0 mm screws from the back case.
    • Because the screws are deeply recessed, use a long, thin driver to remove them.
    询问修复机器人
  3. GameSir Tarantula Pro Joystick Replacement: 步骤 3 中的图像 1,2 GameSir Tarantula Pro Joystick Replacement: 步骤 3 中的图像 2,2
    • Slide a spudger around the seam between the top and bottom cases to release the retaining clips.
    • Remove the bottom case.
    询问修复机器人
  4. GameSir Tarantula Pro Joystick Replacement: 步骤 4 中的图像 1,3 GameSir Tarantula Pro Joystick Replacement: 步骤 4 中的图像 2,3 GameSir Tarantula Pro Joystick Replacement: 步骤 4 中的图像 3,3
    • Use the Phillips #000 screwdriver to remove the nine 4.0 mm screws from the motherboard.
    询问修复机器人
  5. GameSir Tarantula Pro Joystick Replacement: 步骤 5 中的图像 1,3 GameSir Tarantula Pro Joystick Replacement: 步骤 5 中的图像 2,3 GameSir Tarantula Pro Joystick Replacement: 步骤 5 中的图像 3,3
    • Use the point of a spudger to push on alternating sides of each JST connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • If the connector's socket has cutouts, you can insert the arms of a pair of sharp tweezers into the cutouts and gently push the connector out of its socket.
    • Carefully remove the battery from the controller.
    • Avoid bending or puncturing the battery.
    • The battery is secured by double-sided tape, so it may take some work to loosen the adhesive before you can completely remove the battery. Use the iFixit adhesive remover if you have trouble removing the battery.
    询问修复机器人
  6. GameSir Tarantula Pro Joystick Replacement: 步骤 6 中的图像 1,2 GameSir Tarantula Pro Joystick Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the motherboard from the shell.
    • Flip the motherboard over so the joysticks are facing upward.
    询问修复机器人
  7. GameSir Tarantula Pro Joystick Replacement: 步骤 7 中的图像 1,3 GameSir Tarantula Pro Joystick Replacement: 步骤 7 中的图像 2,3 GameSir Tarantula Pro Joystick Replacement: 步骤 7 中的图像 3,3
    • Remove the joysticks by gently pulling them up and off their mounts.
    • When installing the new joystick covers, press them down onto the joysticks until you hear a click, indicating they are securely locked in place.
    询问修复机器人
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eduardo Pereira
于03/02/26注册
195 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-5, Shaddix Spring 2026 UMass Dartmouth, Team 3-5, Shaddix Spring 2026 的会员
UMASSD-SHADDIX-S26S3G5
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 33
总计 40
