跳转到主内容
GameSir T4 Pro Motherboard Replacement
你所需要的
  1. GameSir T4 Pro Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 GameSir T4 Pro Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 GameSir T4 Pro Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the following screws on the back case using a Phillips screwdriver:
    • Two 9.2 mm
    • Two 11.3 mm
    • Insert an opening tool in the seam between the front and back case.
    • Pry around the perimeter until the back case releases.
  2. GameSir T4 Pro Motherboard Replacement: 步骤 2 中的图像 1,2 GameSir T4 Pro Motherboard Replacement: 步骤 2 中的图像 2,2
    • Disconnect the USB-C charger with tweezers.
    • Do not pull on the wires.
  3. GameSir T4 Pro Motherboard Replacement: 步骤 3 中的图像 1,1
    • Gently pry the battery off of the motherboard, with care not to bend the cell.
    • The battery is secured with adhesive. If the adhesive is stubborn, apply a small amount of high-concentration alcohol under the battery to loosen the adhesive.
    • Grip the white battery connector with tweezers and pull it directly out of its motherboard port.
  4. GameSir T4 Pro Motherboard Replacement: 步骤 4 中的图像 1,2 GameSir T4 Pro Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the three 7.1 mm Phillips #0 screws from the motherboard.
    • Remove the two 7.1 mm Phillips #0 screws that secure the trigger assemblies.
  5. GameSir T4 Pro Motherboard Replacement: 步骤 5 中的图像 1,1
    • Lift the motherboard out of the controller.
结论
另外一个人完成了本指南。
Yamini Sri
于04/01/24注册
355 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Harley Spring 2024 IUPUI, Team 1-2, Harley Spring 2024 的会员
IUPUI-HARLEY-S24S1G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 127
