跳转到主内容
GameSir T4 Pro Joystick Replacement
你所需要的
  1. GameSir T4 Pro Joystick Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Joystick Replacement: 步骤 2 中的图像 1,1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Joystick Replacement: 步骤 3 中的图像 1,1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Joystick Replacement: 步骤 4 中的图像 1,1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Joystick Replacement, Joystick: 步骤 5 中的图像 1,2 GameSir T4 Pro Joystick Replacement, Joystick: 步骤 5 中的图像 2,2
    • Disconnect the rumblers from the motherboard
    • Be careful not to pull the wires while disconnecting rumbler
  6. GameSir T4 Pro Joystick Replacement: 步骤 6 中的图像 1,1
    • Using the screwdriver, remove the 5 mm screws from the motherboard
  7. GameSir T4 Pro Joystick Replacement: 步骤 7 中的图像 1,2 GameSir T4 Pro Joystick Replacement: 步骤 7 中的图像 2,2
    • Using the wedge tool, pop the joystick out
  8. GameSir T4 Pro Joystick Replacement: 步骤 8 中的图像 1,2 GameSir T4 Pro Joystick Replacement: 步骤 8 中的图像 2,2
    • Make sure the square of the joystick matches the square of the pad and pop it in place.
结论
另外一个人完成了本指南。
3条评论
I bought ps4 joysticks for the repair, but ps4 joysticks seems larger so it's stuck
Mohamed NACERI - 回复
PlayStation4 stick is not compatible with GameSir T4 Pro. The stick for the Nintendo Switch PRO controller does not interfere, but this also requires processing for installation.
NAKIRI - 回复
It appears that you will need to remove the light diffuser(white tubular plastic sleeve) from the case to make the parts fit.
NAKIRI -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 34
过去 30 天: 184
总计 4,299
