跳转到主内容
GameSir T4 Pro Charging Port Replacement
你所需要的
  1. GameSir T4 Pro Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Charging Port Replacement: 步骤 2 中的图像 1,1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Charging Port Replacement: 步骤 3 中的图像 1,1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Charging Port Replacement: 步骤 4 中的图像 1,1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,2 GameSir T4 Pro Charging Port Replacement, Charging Port: 步骤 5 中的图像 2,2
    • Use the needle nose pliers to remove the plastic connection from the motherboard.
    • You may hold the wires for stability, but do not tug on the wires.
  6. GameSir T4 Pro Charging Port Replacement: 步骤 6 中的图像 1,2 GameSir T4 Pro Charging Port Replacement: 步骤 6 中的图像 2,2
    • Remove the two 5mm screws on the charging port and take out the old charging port.
  7. GameSir T4 Pro Charging Port Replacement: 步骤 7 中的图像 1,2 GameSir T4 Pro Charging Port Replacement: 步骤 7 中的图像 2,2
    • Put your new compatible charging port in place.
    • Make sure to screw in the 5mm screws into your new charing port
结论
一条评论
Where i can buy the charging port? Some buttons isnt working so when i was trying to solve the problem with contact cleaner i ended up breaking the soldered connection
Eron Araújo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 20
总计 847
