简介
Use this guide to replace the charging port of your gameSit T4 Pro with a compatible replacement.
Only replace the charging port of your gameSit T4 Pro if the controller is not registering that it is plugged in and you have ruled out the possibility that the charging cord or power supply are the problem.
你所需要的
Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
Use the needle nose pliers to remove the plastic connection from the motherboard.
一条评论
Where i can buy the charging port? Some buttons isnt working so when i was trying to solve the problem with contact cleaner i ended up breaking the soldered connection
