跳转到主内容
GameSir T4 Pro Battery Replacement
你所需要的
  1. GameSir T4 Pro Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Battery Replacement: 步骤 2 中的图像 1,1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Battery Replacement: 步骤 3 中的图像 1,1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Battery Replacement: 步骤 4 中的图像 1,1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
结论
另外一个人完成了本指南。
3条评论
Battery Model is pl502450 600mah
3.7v
Eugene Eugenio - 回复
Where can I buy this battery? Do You have a link to it?
Roberto Barros -
Roberto Barros - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 105
总计 1,817
