简介
The GameSir G7 SE motherboard replacement guide is intended for users facing complex operational issues stemming from the device's central circuit board. Such problems could range from power issues to unresponsive controls.
Prior to beginning this repair, disconnect the controller from all power sources and prepare ESD-safe tools to prevent damage to electronic components. Due to the complexity of this task, it’s important to follow each step meticulously to avoid further issues.
你所需要的
Use the Phillips #0 screwdriver bit to remove the four 9 mm screws holding the motherboard in place.
