跳转到主内容
Game Boy Speaker Replacement
你所需要的
视频概述
  1. Game Boy Speaker Replacement, Batteries: 步骤 1 中的图像 1,2 Game Boy Speaker Replacement, Batteries: 步骤 1 中的图像 2,2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Speaker Replacement: 步骤 2 中的图像 1,3 Game Boy Speaker Replacement: 步骤 2 中的图像 2,3 Game Boy Speaker Replacement: 步骤 2 中的图像 3,3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Speaker Replacement: 步骤 3 中的图像 1,2 Game Boy Speaker Replacement: 步骤 3 中的图像 2,2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Speaker Replacement, Outer Case: 步骤 4 中的图像 1,1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Speaker Replacement: 步骤 5 中的图像 1,1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Speaker Replacement: 步骤 6 中的图像 1,1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Speaker Replacement: 步骤 7 中的图像 1,1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Speaker Replacement, Speaker: 步骤 8 中的图像 1,1
    • Remove the 10 Phillips #00 screws from the motherboard.
  9. Game Boy Speaker Replacement: 步骤 9 中的图像 1,2 Game Boy Speaker Replacement: 步骤 9 中的图像 2,2
    • Use a plastic opening tool to gently lift the motherboard up and remove it from the front plastic case.
    • Use caution when lifting the board since the speaker is attached.
  10. Game Boy Speaker Replacement: 步骤 10 中的图像 1,3 Game Boy Speaker Replacement: 步骤 10 中的图像 2,3 Game Boy Speaker Replacement: 步骤 10 中的图像 3,3
    • Desolder the two wires connecting the speaker to the motherboard.
    • Remove the speaker.
    • If you're new to soldering, refer to this guide for tips that will help with desoldering the speaker wires and/or soldering the new ones in place.
结论
16等其他人完成本指南。
Andrew Tramposch
于06/24/10注册
2,234 声望
创作了6篇指南
团队
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 的会员
CPSU-JOHANN-R10S3G2
3 名成员
创作了34篇指南
2条评论
This is just a guide to remove the speaker not replacing it so change the title as it is misleading as people that following this will want know how to replace not remove only
Paul - 回复
As stated in the conclusion, you simply follow the steps in reverse to install your replacement speaker.
Jeff Suovanen -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 56
过去 30 天: 260
总计 32,128
