跳转到主内容
Game Boy Pocket Buttons Replacement
你所需要的
  1. Game Boy Pocket Buttons Replacement, Buttons: 步骤 1 中的图像 1,3 Game Boy Pocket Buttons Replacement, Buttons: 步骤 1 中的图像 2,3 Game Boy Pocket Buttons Replacement, Buttons: 步骤 1 中的图像 3,3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Buttons Replacement: 步骤 2 中的图像 1,3 Game Boy Pocket Buttons Replacement: 步骤 2 中的图像 2,3 Game Boy Pocket Buttons Replacement: 步骤 2 中的图像 3,3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Buttons Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the three screws from the motherboard.
  4. Game Boy Pocket Buttons Replacement: 步骤 4 中的图像 1,3 Game Boy Pocket Buttons Replacement: 步骤 4 中的图像 2,3 Game Boy Pocket Buttons Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Buttons Replacement: 步骤 5 中的图像 1,2 Game Boy Pocket Buttons Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Buttons Replacement: 步骤 6 中的图像 1,3 Game Boy Pocket Buttons Replacement: 步骤 6 中的图像 2,3 Game Boy Pocket Buttons Replacement: 步骤 6 中的图像 3,3
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket Buttons Replacement: 步骤 7 中的图像 1,3 Game Boy Pocket Buttons Replacement: 步骤 7 中的图像 2,3 Game Boy Pocket Buttons Replacement: 步骤 7 中的图像 3,3
    • Use your fingers to remove the three silicone button covers.
    • Use a plastic opening tool to remove the buttons.
结论
3等其他人完成本指南。
Adriana Rahrig
于10/07/14注册
1,523 声望
创作了5篇指南
团队
USF Tampa, Team 1-1, Leahy Fall 2014 USF Tampa, Team 1-1, Leahy Fall 2014 的会员
USFT-LEAHY-F14S1G1
4 名成员
创作了18篇指南
一条评论
where can you just buy the a and b buttons (if possible)
Eian Anderson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 43
总计 4,537
