当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
用指甲(或小硬币)向下推电池舱门闩锁,然后卸下电池舱门。
释放闩锁是一个塑料弹簧夹。 如果您的Game Boy好几年了,请小心,因为塑料可能会变脆。
装回主机盖时,在将主机盖推回原位之前,请确保将其两个塑料卡舌插入电池盒底部的插槽中。
Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
Dispose of used batteries properly!
Remove the batteries from your Game Boy before storing it for more than a month or so.
Gently separate the device's front casing from the back casing after you remove the screws.
Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
Separate the front and back casings.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
