跳转到主内容
简介
This guide explains how to remove the outer case so that you can access the internal components of the Game Boy. This will be helpful for other guides related to this hand-held gaming console.
  1. Switch your Game Boy off and remove the cartridge. Switch your Game Boy off and remove the cartridge.
    • Switch your Game Boy off and remove the cartridge.
  2. Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door. The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle. When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Use a fingernail to pry each battery outward from the positive (+) terminal to remove them. Dispose of used batteries properly!
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Remove the six Triwing screws from the back of the device.
    • Remove the six Triwing screws from the back of the device.
  5. Gently separate the device's front casing from the back casing after you remove the screws.
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Slide the front side of the casing down to expose the ribbon cable connector.
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
结论
13等其他人完成本指南。
Andrew Tramposch
于2010年06月24日注册
1,916 信誉积分
创作了6篇指南
团队
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 的会员
CPSU-JOHANN-R10S3G2
3 名成员
创作了30篇指南
2条评论
U need a tri-wing screwdriver not a Philips #00
radiofreeroyaloak - 回复
It is a Philips if gb was made after 1998 or so.
Sam - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 15,601
