跳转到主内容
Game Boy Outer Case Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Game Boy Outer Case Replacement, Batteries: 步骤 1 中的图像 1,2 Game Boy Outer Case Replacement, Batteries: 步骤 1 中的图像 2,2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Outer Case Replacement: 步骤 2 中的图像 1,3 Game Boy Outer Case Replacement: 步骤 2 中的图像 2,3 Game Boy Outer Case Replacement: 步骤 2 中的图像 3,3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Outer Case Replacement: 步骤 3 中的图像 1,2 Game Boy Outer Case Replacement: 步骤 3 中的图像 2,2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Outer Case Replacement, Outer Case: 步骤 4 中的图像 1,1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Outer Case Replacement: 步骤 5 中的图像 1,1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Outer Case Replacement: 步骤 6 中的图像 1,1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Outer Case Replacement: 步骤 7 中的图像 1,1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
结论
13等其他人完成本指南。
Andrew Tramposch
于06/24/10注册
2,243 声望
创作了6篇指南
团队
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 的会员
CPSU-JOHANN-R10S3G2
3 名成员
创作了34篇指南
2条评论
U need a tri-wing screwdriver not a Philips #00
radiofreeroyaloak - 回复
It is a Philips if gb was made after 1998 or so.
Sam - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 15,699
