用指甲(或小硬币)向下推电池舱门闩锁,然后卸下电池舱门。
释放闩锁是一个塑料弹簧夹。 如果您的Game Boy好几年了,请小心,因为塑料可能会变脆。
装回主机盖时,在将主机盖推回原位之前,请确保将其两个塑料卡舌插入电池盒底部的插槽中。
Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
Dispose of used batteries properly!
Remove the batteries from your Game Boy before storing it for more than a month or so.
Gently separate the device's front casing from the back casing after you remove the screws.
Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
Separate the front and back casings.
The headphone jack is located on the bottom of the rear outer casing, near the battery compartment.
Use a Phillips #00 screwdriver to remove the two screws holding the headphone jack in place.
Once the headphone jack is detached it will dangle by the wires attached to the main circuit board. Do not worry about the connections, they are solid and will not break.
Use a Phillips#00 screwdriver to remove the two screws that hold the main circuit board to the casing. This will allow access to the connection points of the headphone jack.
Use a plastic opening tool to remove the main circuit board from the casing.
Once the main circuit board is removed, set aside the outer casing.
Desolder the four wires connecting the headphone jack to the motherboard.
Desolder the four wires connected to the headphone jack
To learn more about soldering, check out iFixit's soldering technique guide.
Remove the headphone jack with tweezers.
嵌入本指南
选择尺寸并复制下面的代码嵌入本指南,为你网站/论坛的一个小插件。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
