跳转到主内容
Game Boy Display Lines/Bars
你所需要的
  1. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: 步骤 1 中的图像 1,3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: 步骤 1 中的图像 2,3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: 步骤 1 中的图像 3,3
    • Remove the back housing by removing the 6 Tri-Point or Philip screws.
    • Note: The last 2 screws are in the battery compartment.
  2. Game Boy Display Lines/Bars: 步骤 2 中的图像 1,2 Game Boy Display Lines/Bars: 步骤 2 中的图像 2,2
    • Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system.
    • Remove the ribbon cable for the next step.
  3. Game Boy Display Lines/Bars: 步骤 3 中的图像 1,3 Game Boy Display Lines/Bars: 步骤 3 中的图像 2,3 Game Boy Display Lines/Bars: 步骤 3 中的图像 3,3
    • Now there will be screws that mount the board to the front, carefully unscrew these.
    • Now remove the board from the housing.
    • Now put the batteries back into the compartment, so you can test the screen while you fix it.
    • Reconnect the the board to back housing with the ribbon cable.
  4. Game Boy Display Lines/Bars: 步骤 4 中的图像 1,1
    • You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
    • Make sure not to touch the screen itself.
    • Note: There may be a rubber strip covering the ribbon.
    • You will start to see the lines of pixels fade in and out, keep moving your iron back and forth until screen is completely black.
结论
6等其他人完成本指南。
Mitchell
于04/03/16注册
184 声望
撰写一个指南
一条评论
Hi, this is the second time I attempt this fix, the first time it worked perfectly. The problem is that with this second machine there's a couple of pixel lines that have not tickled back to black even though I have been patiently going over them for quite some time (2 rounds of 10-15 min) is there anything else that I could try or should I just go on over the same area until I see something happen? Thanks in advance
Jose Saura - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 40
总计 4,435
