跳转到主内容
Game Boy Color Screen Cover Replacement
你所需要的
  1. Game Boy Color Screen Cover Replacement, Battery: 步骤 1 中的图像 1,2 Game Boy Color Screen Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Screen Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Screen Cover Replacement, Screen Cover: 步骤 3 中的图像 1,1
    • Carefully slide a razor blade under one of the corners of the screen cover.
  4. Game Boy Color Screen Cover Replacement: 步骤 4 中的图像 1,1
    • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Continue gently pulling up on the cover until it is fully removed.
结论
24等其他人完成本指南。
团队
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G47
4 名成员
创作了61篇指南
4条评论
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - 回复
You only need step 7 and 8.
h027299c - 回复
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - 回复
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 48
过去 30 天: 187
总计 22,088
