简介
本指南将向你展示如何维修Game Boy Color LED电源指示灯。 当设备开启时,电源指示灯呈红色亮起,表示正在接通电源。
你所需要的
使用#1号十字螺丝刀来拆下图中所示的3颗螺丝。
It’s not mentioned here, but be sure to unplug the LCD flex cable at the top of the motherboard before removing the motherboard. To do so, gently press the clips on either side of the receptacle toward the top of the Game Boy. When they are both pressed up, the orange cable will slide freely out
Thanks Ben. That's a very good point. Just ripping it out will cost you a couple bucks, not to mention your Gameboy will not work until you replace that ribbon cable.
想要重新组装您的设备,请按照本指南相反顺序进行。
7等其他人完成本指南。
由衷感谢以下译者:
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
6条评论
what is the brass color looking thing under the soldering iron in step 7?
That's called 'Desoldering Braid', it sucks up solder like a wick
and what kind of LED are you using to replace?
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
So is the LED a part of the power circuit? in the sense that if it is bad it wont power the console?
