跳转到主内容
Game Boy Color Motherboard Replacement
你所需要的
  1. Game Boy Color Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Game Boy Color Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Motherboard Replacement, Back Housing: 步骤 3 中的图像 1,1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Motherboard Replacement: 步骤 4 中的图像 1,2 Game Boy Color Motherboard Replacement: 步骤 4 中的图像 2,2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Motherboard Replacement, LCD Ribbon Cable: 步骤 5 中的图像 1,1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Motherboard Replacement: 步骤 6 中的图像 1,1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Game Boy Color Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Motherboard Replacement: 步骤 8 中的图像 1,1
    • Gently lift the motherboard from the front housing.
结论
19等其他人完成本指南。
Alex Wu
于01/11/13注册
1,446 声望
创作了2篇指南
团队
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G47
4 名成员
创作了56篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 39
过去 30 天: 231
总计 17,231
