跳转到主内容
Game Boy Color LCD Ribbon Cable Replacement
你所需要的
  1. Game Boy Color LCD Ribbon Cable Replacement, Battery: 步骤 1 中的图像 1,2 Game Boy Color LCD Ribbon Cable Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color LCD Ribbon Cable Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color LCD Ribbon Cable Replacement, Back Housing: 步骤 3 中的图像 1,1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color LCD Ribbon Cable Replacement: 步骤 4 中的图像 1,2 Game Boy Color LCD Ribbon Cable Replacement: 步骤 4 中的图像 2,2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color LCD Ribbon Cable Replacement, LCD Ribbon Cable: 步骤 5 中的图像 1,1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color LCD Ribbon Cable Replacement: 步骤 6 中的图像 1,1
    • Gently remove the ribbon cable from the port
结论
11等其他人完成本指南。
团队
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G47
4 名成员
创作了56篇指南
一条评论
How many pins are in the ribbon?
jakebrown199 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 80
总计 8,336
