跳转到主内容
Game Boy Color LCD Display Replacement
你所需要的
  1. Game Boy Color LCD Display Replacement, Battery: 步骤 1 中的图像 1,2 Game Boy Color LCD Display Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color LCD Display Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color LCD Display Replacement, Back Housing: 步骤 3 中的图像 1,1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color LCD Display Replacement: 步骤 4 中的图像 1,2 Game Boy Color LCD Display Replacement: 步骤 4 中的图像 2,2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color LCD Display Replacement, LCD Ribbon Cable: 步骤 5 中的图像 1,1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color LCD Display Replacement: 步骤 6 中的图像 1,1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color LCD Display Replacement, Motherboard: 步骤 7 中的图像 1,2 Game Boy Color LCD Display Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color LCD Display Replacement: 步骤 8 中的图像 1,1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color LCD Display Replacement, LCD Display: 步骤 9 中的图像 1,2 Game Boy Color LCD Display Replacement, LCD Display: 步骤 9 中的图像 2,2
    • Gently pry and lift the LCD Display from the front panel.
    • Twisting the front casing may help gain more leverage.
结论
38等其他人完成本指南。
团队
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G47
4 名成员
创作了56篇指南
7条评论
I broke my screen doing this. Be really gentle!
Andrew - 回复
Broke my screen just like the last commenter. These instructions are retarded. DON’T pry the screen from the back. Take the front cover off and PUSH it from the front. The circuity for the display is encased in the thin piece of glass all around the LCD. Prying WILL break it!
VoopTech - 回复
Horrible instructions, TBH.
Michelle Fernandez - 回复
Broke the plastic around the screen and doesn't turn on anymore -_- . Guess now I can put a backlit in but not how I wanted it to go
Daniel Guerrero - 回复
Same thing happened to me, but its not really an issue. The way I see it, this is an article for replacing the screen, so it doesnt much matter if the one you’re taking out is broken.
DJ Gunter -
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 118
过去 30 天: 542
总计 52,419
