简介
Sometimes the buttons on the device may stick or become unresponsive, requiring replacement. This guide shows how to replace buttons on the Game Boy Color.
你所需要的
Locate the battery compartment on the back of the Game Boy Color.
Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
It’s not mentioned here, but be sure to unplug the LCD flex cable at the top of the motherboard before removing the motherboard. To do so, gently press the clips on either side of the receptacle toward the top of the Game Boy. When they are both pressed up, the orange cable will slide freely out
Thanks Ben. That's a very good point. Just ripping it out will cost you a couple bucks, not to mention your Gameboy will not work until you replace that ribbon cable.
24等其他人完成本指南。
2条评论
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
