跳转到主内容
修复你的物品
维修的权力
商店
简介
Sometimes the buttons on the device may stick or become unresponsive, requiring replacement. This guide shows how to replace buttons on the Game Boy Color.
  1. Locate the battery compartment on the back of the Game Boy Color. Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Remove the batteries from the battery compartment.
    • Remove the batteries from the battery compartment.
  3. Using a Y1 screwdriver, remove the six screws on the back of the device as pictured.  The bottom two screws are located inside of the battery compartment.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out! Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out!
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Push up on the tabs on either side of the ribbon with a spudger.
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Gently remove the ribbon cable from the port
    • Gently remove the ribbon cable from the port
  7. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Gently lift the motherboard from the front housing.
    • Gently lift the motherboard from the front housing.
  9. Remove the rubber backing on each button grouping.
    • Remove the rubber backing on each button grouping.
  10. Remove the original buttons from the housing.
    • Remove the original buttons from the housing.
结论
15等其他人完成本指南。
Nick Katsantones
于2013年01月18日注册
613 信誉积分
创作了4篇指南
团队
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G47
4 名成员
创作了36篇指南
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 33
过去的30天: 146
总计 20,623
