简介
塑料外屏位于LCD屏幕的前方。 本指南将指导您更换Game Boy Color 外屏。
你所需要的
使用#1号十字螺丝刀来拆下图中所示的3颗螺丝。
It’s not mentioned here, but be sure to unplug the LCD flex cable at the top of the motherboard before removing the motherboard. To do so, gently press the clips on either side of the receptacle toward the top of the Game Boy. When they are both pressed up, the orange cable will slide freely out
Thanks Ben. That's a very good point. Just ripping it out will cost you a couple bucks, not to mention your Gameboy will not work until you replace that ribbon cable.
想要重新组装您的设备,请按照本指南相反顺序进行。
24等其他人完成本指南。
由衷感谢以下译者:
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
