跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Game Boy Advance,应参考我们的维修指南
  1. Game Boy Advance Teardown, Game Boy Advance Teardown: 步骤 1 中的图像 1,3 Game Boy Advance Teardown, Game Boy Advance Teardown: 步骤 1 中的图像 2,3 Game Boy Advance Teardown, Game Boy Advance Teardown: 步骤 1 中的图像 3,3
    • Remove the back battery cover by pinching down on the tab and pulling outward.
  2. Game Boy Advance Teardown: 步骤 2 中的图像 1,1
    • Remove the six back panel screws using a Y1 screw driver.
  3. Game Boy Advance Teardown: 步骤 3 中的图像 1,1
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  4. Game Boy Advance Teardown: 步骤 4 中的图像 1,1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Beware of right and left triggers, the right and left panels, and the power switch falling off as the back panel is removed.
  5. Game Boy Advance Teardown: 步骤 5 中的图像 1,2 Game Boy Advance Teardown: 步骤 5 中的图像 2,2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels.
    • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Game Boy Advance Teardown: 步骤 6 中的图像 1,2 Game Boy Advance Teardown: 步骤 6 中的图像 2,2
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Game Boy Advance Teardown: 步骤 7 中的图像 1,1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
    • The last screw on the right is not included on some Game Boy Advance systems.
  8. Game Boy Advance Teardown: 步骤 8 中的图像 1,2 Game Boy Advance Teardown: 步骤 8 中的图像 2,2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Beware not to damage the top ribbon by pulling up gently.
  9. Game Boy Advance Teardown: 步骤 9 中的图像 1,3 Game Boy Advance Teardown: 步骤 9 中的图像 2,3 Game Boy Advance Teardown: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  10. Game Boy Advance Teardown: 步骤 10 中的图像 1,3 Game Boy Advance Teardown: 步骤 10 中的图像 2,3 Game Boy Advance Teardown: 步骤 10 中的图像 3,3
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
  11. Game Boy Advance Teardown: 步骤 11 中的图像 1,3 Game Boy Advance Teardown: 步骤 11 中的图像 2,3 Game Boy Advance Teardown: 步骤 11 中的图像 3,3
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
    • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
  12. Game Boy Advance Teardown: 步骤 12 中的图像 1,1
    • Use the tweezers to remove the black tape if needed.
Adam
于01/20/10注册
889 声望
创作了6篇指南
团队
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G29
5 名成员
创作了81篇指南
8指南评论
used this to replace the case and buttons on my GBA worked like a charm thanks!
Josh - 回复 分享
I dont understand. The items in “Tools featured in this teardown" is different from the tools written on the article e.g. Y0 in “featured" but Y1 in the “article”.
darelldechavez - 回复 分享
Buy a small electric tool kit and test both, they will probably be different sizes in different models of the console
Gaget - 分享
Bruh thx for
ColdPizza - 回复 分享
Great guide. My dumb ass didn’t see the screws holding the circuit board to the front shell lmao
RikaSprout - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 35
过去 7 天: 295
过去 30 天: 1,318
总计 90,994
