跳转到主内容
Game Boy Advance Speakers Replacement
你所需要的
  1. Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: 步骤 1 中的图像 1,3 Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: 步骤 1 中的图像 2,3 Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: 步骤 1 中的图像 3,3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Speakers Replacement, Unscrew the Back Panel: 步骤 2 中的图像 1,2 Game Boy Advance Speakers Replacement, Unscrew the Back Panel: 步骤 2 中的图像 2,2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Speakers Replacement, Remove the Back Panel: 步骤 3 中的图像 1,1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Speakers Replacement, Remove Triggers: 步骤 4 中的图像 1,2 Game Boy Advance Speakers Replacement, Remove Triggers: 步骤 4 中的图像 2,2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - 回复
  5. Game Boy Advance Speakers Replacement, Remove the On/Off Switch: 步骤 5 中的图像 1,1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Game Boy Advance Speakers Replacement, Buttons: 步骤 6 中的图像 1,3 Game Boy Advance Speakers Replacement, Buttons: 步骤 6 中的图像 2,3 Game Boy Advance Speakers Replacement, Buttons: 步骤 6 中的图像 3,3
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  7. Game Boy Advance Speakers Replacement, Speakers: 步骤 7 中的图像 1,3 Game Boy Advance Speakers Replacement, Speakers: 步骤 7 中的图像 2,3 Game Boy Advance Speakers Replacement, Speakers: 步骤 7 中的图像 3,3
    • Using the tweezers, gently pull the ribbon from the logic board.
    DO NOT USE TWEEZERS ON THE RIBBON CABLE. DO NOT PULL ON THE RIBBON CABLE LIKE THAT.
    theres 2 brown tabs on each side of the connector. You slide both those up and the ribbon cable slides right out with no need to use tweezers. Don't risk damaging your ribbon cable.
    Vincent C. - 回复
  8. Game Boy Advance Speakers Replacement: 步骤 8 中的图像 1,3 Game Boy Advance Speakers Replacement: 步骤 8 中的图像 2,3 Game Boy Advance Speakers Replacement: 步骤 8 中的图像 3,3
    • Slightly move the speaker to the right and desolder the two wires from the logic board.
    • Beware of over heating the soldering kit will damage the logic board.
终点
9等其他人完成本指南。
Adam
于01/20/10注册
815 声望
创作了5篇指南
团队
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G29
5 名成员
创作了61篇指南
一条评论
When no sound in GBA. Is the broken speaker the most common problem ? Or some SMD part in circuit board ? What to do if the new replaced speaker emits no sound ?
Pekka Hollola - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 134
总计 14,202
