跳转到主内容
Game Boy Advance Shoulder Button and Side Panels Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the battery cover: 步骤 1 中的图像 1,3 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the battery cover: 步骤 1 中的图像 2,3 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the battery cover: 步骤 1 中的图像 3,3
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
  2. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the batteries: 步骤 2 中的图像 1,3 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the batteries: 步骤 2 中的图像 2,3 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the batteries: 步骤 2 中的图像 3,3
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
  3. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the back shell screws: 步骤 3 中的图像 1,2 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the back shell screws: 步骤 3 中的图像 2,2
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
  4. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the back shell: 步骤 4 中的图像 1,2 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the back shell: 步骤 4 中的图像 2,2
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
  5. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: 步骤 5 中的图像 1,2 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: 步骤 5 中的图像 2,2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
结论
4等其他人完成本指南。
Aldo Corona
于01/25/10注册
886 声望
创作了8篇指南
团队
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G29
5 名成员
创作了81篇指南
1指南评论
i need help th e side pannels loose
Mark - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 8,945
