跳转到主内容
Galaxy Tab S 10.5 Battery Replacement
你所需要的
  1. Galaxy Tab S 10.5 Battery Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: 步骤 1 中的图像 1,2 Galaxy Tab S 10.5 Battery Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: 步骤 1 中的图像 2,2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Galaxy Tab S 10.5 Battery Replacement: 步骤 2 中的图像 1,1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Galaxy Tab S 10.5 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Galaxy Tab S 10.5 Battery Replacement, Battery: 步骤 4 中的图像 1,3 Galaxy Tab S 10.5 Battery Replacement, Battery: 步骤 4 中的图像 2,3 Galaxy Tab S 10.5 Battery Replacement, Battery: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers, peel back the green tape from the ZIF connectors on the two black ribbon cables.
    • Use a plastic opening tool to lift up the plastic clips on the ZIF connectors.
  5. Galaxy Tab S 10.5 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the six 2mm screws Phillips #000 screws surrounding the battery.
  6. Galaxy Tab S 10.5 Battery Replacement: 步骤 6 中的图像 1,3 Galaxy Tab S 10.5 Battery Replacement: 步骤 6 中的图像 2,3 Galaxy Tab S 10.5 Battery Replacement: 步骤 6 中的图像 3,3
    • Place the plastic opening tool between the frame and battery.
    • Move the plastic opening tool in a downward motion, away from the battery to bring the battery out of the device.
  7. Galaxy Tab S 10.5 Battery Replacement: 步骤 7 中的图像 1,3 Galaxy Tab S 10.5 Battery Replacement: 步骤 7 中的图像 2,3 Galaxy Tab S 10.5 Battery Replacement: 步骤 7 中的图像 3,3
    • Hold the battery and disconnect the plug to remove the battery.
结论
83等其他人完成本指南。
Jordan Soto
于08/26/15注册
3,276 声望
创作了6篇指南
团队
USF Tampa, Team 3-2, Eyestone Fall 2015 USF Tampa, Team 3-2, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S3G2
3 名成员
创作了20篇指南
20指南评论
where is a good place to buy a replacement battery?
brianference - 回复
Artículo muy positivo: pasos muy bien detallados. Me ha resultado fácil la el cambio de batería. Gracias por tu colaboración.
Miguel Ángel - 回复
Bought mine off of ebay
Jerry Belschner - 回复
Great guide! Thanks a lot!
Markus - 回复
I bought a battery but am afraid to do the replacement myself. Where can I take the tablet to have it done?
Barb - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 32
过去 30 天: 154
总计 101,807
