你所需要的
手机在usb-c的针脚上检测到的了不应该有的电阻. 如果充电口上有水或者湿度太高,就会引发警告/警告声,并且停止充电.
插充电线时检查是否有水.
盐水和含氯的溶液对接口都是有损害的千万不要用这样的插头充电. 清洁插头并且让插头干燥,这可以救你的手机和充电器一命.
不要用潮湿的充电器插头充电.
不要用潮湿的充电器插头充电.
19等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
32条评论
The alert go away on its own, when the connector issue is not present anymore.
However it is strongly suspected that the same mechanism is active inside the phone, so it screen is broken
or the sealing on the phone is not working anymore - it could be moisture inside the phone that cause the issue.
If this happens, I would leave phone on a heat source (radiator etc.) to dry out , at about 30-40 DEG C.
If someone have more info or experience on this topic, please leave in the comments :o)
I have a S9, it is showing the moisture problem and my battery is dead, can not charge it, I live in Zambia and do not have an Samsung repair shop close to me, is there anything else I can do to fix?
same did you fix the issue?
Press volume down and power key at the same time and then have someone put in the charger for u release when phone starts to charge
Kurtney Flavien, eres un crack. Muchas gracias
