跳转到主内容
Galaxy Note 2 - N7100 Complete Disassembly & Assembly
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
视频介绍
结论
To reassemble your Galaxy Note, follow the complete video
51等其他人完成本指南。
LE55ONS
于05/30/12注册
10,977 声望
创作了6篇指南
12条评论
Brilliant. Thank you.
churchst71 - 回复
Very complete guide. If you need to replace your screen - MAKE SURE you order the part with the plastic chassis and home key attached to the glass. You will be much happier, trust me.
Justin Long - 回复
Also-
In the linked video which describes separating the digitizer and glass from the plastic chassis I believe there is a missing step in the reassembly which is critical.
There is a metal grommet on the glass which holds the home button in place when it is reattached to the plastic chassis. This piece of metal MUST be transfered if it's not on the new glass/digitizer assembly. If this step is omitted, the home button will not seat properly and will probably just fall out. The worst part is you can't really go back and fix it once you've mated the glass/digitizer to the plastic chassis. As soon as I hit it with heat again, the glass separated from the digitizer and rendered my new screen useless.
If I missed something, I apologize, but its a very important step nonetheless!!
Justin Long - 回复
Excellent. Thx!!
Tom Retson - 回复
My Note 2 can't make calls even though showing full bars, how can I test whether it's a radio/antennae problem or software problem or if something is fried on the motherboard? For more info please see my question I just posted, thanks for the great video!
David - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 62,736
