跳转到主内容
Galaxy J3 Prime LCD Screen Replacement
你所需要的
视频概述
    • Remove the back cover and battery.
    • Heat up the screen to loosen the adhesive.
    • You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
    • Put a spudger between the phone frame and the front display.
    • Remove the plastic bracket that will be visible when you pry up the screen.
    • Gently pull up on the LCD screen adhesive to remove the screen.
    • Remove the screws on the back of the phone frame that are holding the housing of the phone together.
    • Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
    • Be gentle so you don't break anything.
    • Disconnect the metal flex cable from the charging port.
    • Remove the Motherboard from the housing.
结论
9等其他人完成本指南。
Brian Brown
于09/26/16注册
393 声望
撰写一个指南
3条评论
great guide, this really helped
anonymous 591 - 回复
thanks for your help, this has really helped
Marvinhenderson4@gmail.com - 回复
Best guide for a J3 out there professional and easy to follow
Keith Pobuta - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 6,951
