跳转到主内容
Galaxy Book3 360 13" SSD Replacement
你所需要的
  1. Galaxy Book3 360 13" SSD Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • Flip the laptop over and remove each rubber shoe
    • Use a Philips screwdriver to care fully remove each screw
  2. Galaxy Book3 360 13" SSD Replacement, Remove the Case: 步骤 2 中的图像 1,2 Galaxy Book3 360 13" SSD Replacement, Remove the Case: 步骤 2 中的图像 2,2
    • After removing the screws carefully pry open the case starting on the top right hinge.
    • There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
  3. Galaxy Book3 360 13" SSD Replacement, Replace the SSD: 步骤 3 中的图像 1,1
    • Carefully remove the screw holding down the SSD.
    • Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
    • Slide in your new SSD, and follow the previous steps in reverse.
结论
7等其他人完成本指南。
Dan
于02/18/19注册
4,985 声望
创作了9篇指南
5指南评论
Are you sure for the second slot it is 2280 and not 2230?
Jeremy Asher - 回复
How can I be sure for my NP750QFG that it's 2280 and not 2230?
Any advice?
Jeremy Asher - 回复
Galaxy book 3 360 15.6" inch variant support Gen 3 NVMe 2280 type ssd like WD Black SN770
Biswajit Shial -
Mine is 15.6 size and it's for the second slot, the 13" I think didn't have a second slot.
How do I know i it's for 2230 or 2280?
Jeremy Asher - 回复
I opened my Book3 Pro 360 5G and the SSD is covered by a metal shield. How do I remove this shield to gain access to the SSD and slot?
Lloyd Franklin - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 62
过去 30 天: 323
总计 16,094
