跳转到主内容
GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard
你所需要的
  1. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard, Graphics Processing Unit (GPU): 步骤 1 中的图像 1,2 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard, Graphics Processing Unit (GPU): 步骤 1 中的图像 2,2
    • Make sure your Computer is off before starting!
    • Unplug your desktop from the wall outlet.
    • Turn your desktop so you have access to the back of the device.
  2. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 2 中的图像 1,2 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 2 中的图像 2,2
    • Switch off the PSU to prevent power flow.
    • Unplug your desktop to prevent any power flow.
  3. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 3 中的图像 1,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 3 中的图像 2,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 3 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the two 15 mm screws on the glass panel side and remove the panel.
  4. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 4 中的图像 1,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 4 中的图像 2,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 4 中的图像 3,3
    • Gently remove the glass panel, by sliding it towards yourself.
    • The panel contains glass so be gentle with it!
    • The GPU is highlighted.
    • Using the Phillips #0 screwdriver, remove the three 14 mm screws connecting the GPU to the case.
    • Unplug the power cable on the GPU.
  5. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 5 中的图像 1,1
    • Unplug the GPU from the power supply, since we need to remove anything connected to it.
  6. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 6 中的图像 1,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 6 中的图像 2,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 6 中的图像 3,3
    • Use the Phillips #0 to remove the three 14mm Phillips screws from the GPU and motherboard so we can remove the GPU later.
  7. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 7 中的图像 1,2 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 7 中的图像 2,2
    • Push down on the tab to unlock the GPU.
    • The tab unlocks easily, so don't apply too much force.
  8. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 8 中的图像 1,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 8 中的图像 2,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 8 中的图像 3,3
    • Gently pull the old GPU out.
    • The PCI-E slot is now empty for a new GPU.
  9. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 9 中的图像 1,1
    • Line up the GPU with the PCI-E Slot.
    • Push the GPU in, make sure to line it up properly with the PCI-E and the rear end of the case.
    • The tab will click in when you push the GPU in.
  10. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 10 中的图像 1,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 10 中的图像 2,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 10 中的图像 3,3
    • Screw the three 14 mm Phillips screws back in using the Phillips #0 screwdriver.
  11. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 11 中的图像 1,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 11 中的图像 2,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 11 中的图像 3,3
    • Reconnect the 8-Pin Male Cable from the PSU into the GPU to power it when we turn it on.
  12. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 12 中的图像 1,1
    • Slide the glass panel back in.
  13. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 13 中的图像 1,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 13 中的图像 2,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 13 中的图像 3,3
    • Using the Phillips #0 screwdriver, screw in the two 15 mm screws back into the case to lock the panel into place.
  14. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 14 中的图像 1,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 14 中的图像 2,3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: 步骤 14 中的图像 3,3
    • Connect the female part of the power cord into the PSU.
    • Turn on the switch and power on your PC.
结论
The brand or generation of GPU you intend to install does not matter, as long as it can fit the PCI-E slot located on your motherboard.
另外一个人完成了本指南。
Faiz Khan
于01/19/21注册
265 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 3,110
