简介
Follow this guide to learn how to replace the battery of your GPD Win. Be sure to power off your device prior to starting the guide.
你所需要的
Carefully insert the pry tool between the keyboard and case.
Move the tool around the edge until every clip is released.
Carefully lift the back half of the case.
You'll see a small ribbon connector on the right. Use your pry tool to remove it by lifting up.
On the right, you'll see another white connector going to the battery. Use the pry tool and pull back on the connector to release it.
3等其他人完成本指南。
1指南评论
At the moment, the Shenzhen Zero Five Battery Company replacement comes with two wires crossed. You'll need a small metal pick to pry the clips open enough to pull the conductors out and swap them over. It should be red, yellow, black. I've performed the modification and can confirm it works after switching the contacts.
