跳转到主内容
GP Percussion DP778TN Double Bass Pedal Assembly Technique
你所需要的
  1. GP Percussion DP778TN Double Bass Pedal Assembly Technique, GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 1 中的图像 1,1
    • Lay everything out
  2. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 2 中的图像 1,2 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 2 中的图像 2,2
    • Remove the drum key and Allen wrenches from the right side of the primary pedal.
  3. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 3 中的图像 1,2 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 3 中的图像 2,2
    • Slide the ends of the long black connector onto the sides of the pedals.
    • Both sides of the connection are shaped like a half-circle, so they can only connect in the proper orientation.
    • Ensure all the screws on the connector are pointing up. To do so, you will need to "wind" the secondary pedal up manually before attaching the connector.
  4. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 4 中的图像 1,2 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 4 中的图像 2,2
    • Insert the beaters into the primary pedal.
    • You can choose to use either side of the beaters - just be consistent!
  5. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 5 中的图像 1,3 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 5 中的图像 2,3 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 5 中的图像 3,3
    • Arrange the pedals in the drumkit. The primary pedal should be centered on the kick drum, while the secondary pedal should be wherever comfortable.
    • If necessary use the drum key to adjust the height of the beaters to be vertically centered on the kick drum.
    • Now tighten everything down!
  6. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 6 中的图像 1,1
    • Tighten and loosen the nuts on the bottom of the springs until both pedals have an even, comfortable tension.
  7. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 7 中的图像 1,2 GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 7 中的图像 2,2
    • Replace the tools in the pedal for safe-keeping.
    • Bag the extra parts in case you want to convert your double-bass pedal into two singles.
  8. GP Percussion DP778TN Double Bass Pedal Assembly Technique: 步骤 8 中的图像 1,1
    • Pound out some sick beats!
终点
6等其他人完成本指南。
团队
eXifiters eXifiters 的会员
Community
1 名成员
创作了1篇指南
一条评论
Nice to see some double bass enthusiasts on here! I am in the process of building an electronic midi drumset from piezos, some old stationary cardio equipment and an alesis dm5. The tooling, oh the tooling. Taps and dies, welding, now i need a lathe to make a double bass pedal from scratch... Www.gpsn.uspto.gov is a great resource for technical info and also creepy government technology. Ill post when i can. Peace
Scott Haddox - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 2,792
