跳转到主内容
GMMK-BRN Keyboard Switch Replacement
你所需要的
  1. GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: 步骤 1 中的图像 1,2 GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: 步骤 1 中的图像 2,2
    • Unplug the keyboard from your device.
    • Place the keyboard on a clean workspace, along with the tools required.
  2. GMMK-BRN Keyboard Switch Replacement: 步骤 2 中的图像 1,3 GMMK-BRN Keyboard Switch Replacement: 步骤 2 中的图像 2,3 GMMK-BRN Keyboard Switch Replacement: 步骤 2 中的图像 3,3
    • Use your fingers or a keycap remover and pull directly upward to remove the keycap.
    • It is possible to damage the keycap if not pulled directly upwards.
  3. GMMK-BRN Keyboard Switch Replacement: 步骤 3 中的图像 1,2 GMMK-BRN Keyboard Switch Replacement: 步骤 3 中的图像 2,2
    • Use the switch remover to push the tabs in on the opposite sides of the switch.
    • Firmly pull the switch upwards.
    • If the switch is pulled at an angle, there is a risk to damaging the switch.
    • The switch may not come out easily, so more force may be required.
  4. GMMK-BRN Keyboard Switch Replacement: 步骤 4 中的图像 1,3 GMMK-BRN Keyboard Switch Replacement: 步骤 4 中的图像 2,3 GMMK-BRN Keyboard Switch Replacement: 步骤 4 中的图像 3,3
    • Align the pins on the keycap with the ones inside the keyboard.
    • Insert the switch, and press down firmly until a click is heard.
  5. GMMK-BRN Keyboard Switch Replacement: 步骤 5 中的图像 1,3 GMMK-BRN Keyboard Switch Replacement: 步骤 5 中的图像 2,3 GMMK-BRN Keyboard Switch Replacement: 步骤 5 中的图像 3,3
    • Align the cross of the keycap with the cross of the switch.
    • Push the keycap down firmly to reattach.
  6. GMMK-BRN Keyboard Switch Replacement: 步骤 6 中的图像 1,2 GMMK-BRN Keyboard Switch Replacement: 步骤 6 中的图像 2,2
    • Plug the keyboard back into your device.
    • Turn you device on and do a test to see if the new switch works.
结论
Kyle Lieu Dang
于01/30/23注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 25
总计 635
